I have a NVR HWN-2104MH from Hikvision with a camera on POE also from Hikvision.
I used SADP tool to activate the camera and give it a 192.168.1.160 as an IP and NVR has .155
Internally NVR attributed a different network IP such as 192.168.254.3 and is working perfectly.
Now I bought a second IP camera modelDS-2CD1067G which got the IP 192.168.1.140 on activation with SADP tool.
I connect it to NVR which assigned 192.168.254.8 automatically but camera was not working as network could not be reached.
So , chat GPT said as info that I should put with SADP tool the address which NVR assigned to the camera.
And to change to ONVIF protocol.
I did it and worked.
Now the question is …. Why I need it to change the protocol to ONVIF from HIKVISION and why NVR cannot deal to switch networks.
I did something wrong or?
