Cameras and AcuSeek compatibility
Chucky
Greetings.
Recently I saw this AI search think (you write a promp into acu seek like "guy in yellow" and it will find you videos with person in yellow) and i would like to give it a try. I just cant find much info about compatibility (or im overthinking). Okey, so what i know is I need this AI NVR - Hikvision DS-7732NXI-I4/VPro should do the charm AFAIK.
Now about cameras. Are all (any) AcuSense cameras compatible and will work with this AI search, or just some newer models or do i need explicitelly som AI cameras also ?
Are these: DS-2CD2T47G3-LIS2UY/SL, DS-2CD2T46G2P-ISU/SL-(2.8mm)(C), DS-2CD2147G3-LIS2UY compatible ? How do I know ?
Are there any catches to this acu seek search thingy ? Is it worth it ? (I dont like manual searching at all)
Is Acuseek in IVMS4200 available ?
Thanks so much
It’s available with AcuSense cameras that have AcuSearch available. Models DS-CD2xxxG2 have it so long as they’re the (c) model (which use G5 rather than G3 firmware). The new 2CD2xxxG3 models have it. The one I’m not sure about is the panoramic (G2P) I could be wrong but seem to remember from a post on here that it doesn’t support something.
It works quite well but it’s early days. As an installer I’ve had my own about 7 months but notice that they’re still not listed as available by my suppliers.
Not sure about iVMS but it works in Hik-Connect and browser as well as locally.
One ‘gotcha’ would be if you’re replacing an NXI NVR where you’re currently using that NVRs AcuSense features for standard non AcuSense cameras. If the resources on the VPro NVR are to be used for AcuSeek and AcuSearch, they’re not available for AcuSense (not enough available algorithm engines) So all cameras need to have the AcuSense feature.
G2P are not supported
Ivms4200 work
HikConnect work
WebInterface work
LocalGUI work
