Looking for a solution to run a Hikvision camera over ethernet in excess of 100m.
Currently have a 2CD2042 operating on a 60m Cat6 cable to a powerline adapter which runs the signal to the house. This isn't an ideal setup and severely limits the bandwidth I can run for the mainstream. I want to get rid of the powerline portion of the line and run LAN/Ethernet for the total distance ~130m. To avoid the 100m ethernet max limit for Cat5/6, I plan to replace the powerline adaptor with switch to repeat the signal for the next distance of additional cable (~70m). Does this sound like a reasonable solution to this length wiring run?
Additionally I plan to upgrade to a 2CD2045 or 2CD2T45 to take advantage of the 265+ encoding which should also help
