Geovision End of Life Products
If you're reading this it means you've probably been redirected from an End of Life product.
It's common practice for Geovision to replace old products with models from a new series. These products are known as "End of Life" and are no longer available to buy on the market.
The below list is designed to direct you to the current replacement for Geovision End of Life models.
PLEASE NOTE:
- Check the specifications of the replacement models to check that they match your requirements
- Some End of Life models don't have a direct replacement. Please feel free to contact us if you require some advice or recommendations for these models
- With this Post open on your PC, please press CTRL + F on your keyboard (Command + F on a Mac)
- Type in the Geovision product code and press ENTER to search
- Clicking on the link of the current model will take you to the corresponding product page.
DOMES
GV-IPDOME
GV-EDR1100 → GV-EDR2700
GV-EDR2100 → GV-EDR2700
GV-EFD2100 → GV-EFD2700
GV-FD1200 → GV-VD2702
GV-FD1210 → GV-VD2712
GV-FD2410 → GV-VD2712
GV-FD3410 → GV-VD4712
GV-FD2400 → GV-VD3700
GV-FD3400 → GV-VD3700
GV-FD5300 → GV-VD4702
GV-FD120D → GV-VD2702
GV-FD220D → GV-VD2702
GV-FD320D → GV-VD4702
GV-MFD110
GV-MFD1501
GV-MFD2401
GV-MFD3401
GV-MFD130
GV-MFD220
GV-MFD320
GV-MFD520
GV-MDR120
GV-MDR220
GV-MDR320
GV-MDR520
GV-VD1500 → GV-VD3700
GV-VD120D → GV-VD2702
GV-VD220D → GV-VD2702
GV-VD320D → GV-VD4702
BULLETS
GV-IP
GV-BL110D
GV-BL1200 → GV-BL2702
GV-BL1500 → GV-BL2702
GV-BL2400 → GV-BL2702
GV-BL3400 → GV-BL4702
GV-BL3700 → GV-BL4713
GV-BL5700 → GV-BL5713
GV-BL1210 → GV-BL4713
GV-BL2410 → GV-BL4713
GV-BL3410 → GV-BL4713
GV-BL5310 → GV-BL5713
GV-EBL1100 → GV-EBL2702
GV-EBL2100 → GV-EBL2702
GV-UBL1211 → GV-BL4713
GV-UBL2411 → GV-BL4713
GV-UBL3411 → GV-BL4713
GV-UBL1301
GV-UBL2401
GV-UBL3401
FISHEYES
GV-FE421
GV-FE521
GV-FE2301
GV-FE4301
GV-FE5302
GV-FE5303
GV-FE3402
GV-FER521
BOX CAMERAS
GV-HYBRID
GV-SDI-BX
GV-BX140DW
GV-BX110D
GV-BX120D
GV-BX220D
GV-BX320D
GV-BX1300 → GV-BX2700
GV-BX1500 → GV-BX2700
GV-BX2400 → GV-BX2700
GV-BX3400 → GV-BX4700
GV-BX5300 → GV-BX5700
GV-BX520D
GV-UBX1301 → GV-BX2700
GV-UBX2301 → GV-BX2700
GV-UBX3301 → GV-BX4700
GV-BX120D-E
GV-BX220D-E
GV-BX320D-E
GV-BX520D-E
GV-BX5300-E
GV-BX3400-E
GV-BX2400-E
GV-BX1500-E
PTZs
GV-PT110D
GV-PT130D
GV-SD010 →
GV-SD200
GV-SD200S
GV-SD220 → GV-SD2723-IR
GV-SD220S → GV-SD2723-IR
GV-SD2411 → GV-SD2723-IR
GV-SD2301 → GV-SD2723-IR
GV-SD2322-IR → GV-SD2723-IR
CUBE
GV-CB120
GV-CBW120
GV-CBW220
VIDEO SERVERS
GV-VS04H
GV-VS11 → GV-VS2400
GV-VS12 → GV-VS2400
GV-VS14 → GV-VS2400
ACCESSORIES
GV-IP
GV-VIDEO
