NVR 104MH-C/4P Network misconfiguration
NickSM
Hi all , a friend on mine bought one NVR 104MH-C/4P .. (2) DS-2CD2763G0-IZS 6MP and (1)IPC-T250H ip camera
I installed the camera in his house and connected all Ethernet cable to NVR and started the setup from the beginning. I finished the setup and I could see both 2 DS-2CD2763G0-IZS 6MP they appeared on monitor but not the IPC-T250H .. I was shocked ..how the 2 ip cameras without giving them IP address they are active and without adding them are displayed on the monitor, when I try to check the network and to check the ip address.
They has 192.168.254.6 the other 192.168.254.7, I said this isn't right, which my Default Gateway 192.168.0.1, I tried to edit manually to give some ip address witch is not been use,edit them with right ip address and password but still not successful also the same IPC-T250H. then after i choose the other option plug and play and they displayed as active as well.. but still with the ip address ...
My question is how they work with different default gateway ..this (2) DS-2CD2763G0-IZS 6MP but not the IPC-T250H..
Also I created the hik-connect app and he can watch live on his mobile phone ..
Do I change the ip address with SADP Tool then add them to NVR. I really don't understand how this works like which NVR have the right ip address 192.168.0.50..
Please let me know your thoughts.
Regards Nick
Sorry, your post got held for approval and we didn't notice it :confused:
Are you still having problems?
