NVR - Remote Configuration access errors
JXBURNS
iVMS-4200 v3.6.0.6 / NVR DS-7732-NI/24P.
Added NVR to iVMS not a problem and online. But whenever I try to use the Remote Configuration option all I get is the attached error regarding HCNetSDK. In all other respects the NVR is working fine and I can access all 30 cameras remotely either in the VMS or via a browser. Obviously I want to be able to change settings without having to constantly go to the building.
Tried via Hik-Connect however that does not work either and gives the second error message.
So at moment I cannot update the NVR remotely.
Any ideas?
Thanks - John
Someone suggested "See if Auto Change Stream Type is enabled in ivms 4200 and disable it." but message has been removed. That option (which should be under System Config -> Image or Right Click Group is not present on latest version. If that really is a solution can someone explain where? Thanks.
