Password
  • Thread starter Thread starter g19aby
  • Start date Start date
G
g19aby
Guest
There is very little info on the system i have purchased.
on the face of of it easy to connect but im having issues to operate it.
I need a password to get into the machine?
When first setting up the username should be admin and password leave (blank) You should be then prompted to assign your own password.
Hi Harri, thak's for the reply.
On the screen i right click on chan one and hit menu, then you have two options admin or user. I click on admin and a box opens up asking for password but only giving options for numbers only. When i click a number in it or leave it blank and hit ok i get mismatch!
Hi thanks, i did find the user guide in the end which was on the cd supplied.
I also found the password which was 1234 standard to access the nvr so im able to play with the settings.
