Startup interrupted by UAC prompt for LocalServiceControl.exe (installed by iVMS4200)
Leodan
Since installing iVMS4200 Client (3.12.2.3), my Windows 10 startup is interrupted by UAC asking permission to load LocalServiceControl.exe. This slows startup and I would like to know how I can get UAC to ignore \ accept this service and let windows startup without my intervention.
I got fedup with this before and uninstalled iVMS, but I continued to get the UAC message even though the file: LocalServiceControl.exe, no longer existed.
I know your pain. You also need LocalServiceControl active if you view your cameras through a browser. I am on Windows 11, but generally same actions for Windows 10. Anyway, what I did was;
Open Task Manager, goto Startup, right click on LocalServiceControl and select Disable. This will stop it autostarting.
Because I need it for browser access, I added an entry to Task Scheduler instead to autostart it when I log on using privilages which avoids getting the UAC message :-) I've had it this way for a few years now.
Hi - I took your suggestion and it did solve the issue, thanks. I'd forgotten about that option. I had tried using Task Schedular, as you also mention, but it didn't work - I must not have done it properly.
