Leds IR failure repair camera
dixibru
Hi guys, I disassembled the minidome camera DS2CD2112F-IW because the light IR does not work. I have tested with multimeter all IR leds and I found 5 faulty leds. Other 25 leds are good. Where I find it the replacement leds?
what are the characteristics? voltage and wavelength?
Thanks for your suggestion.
Bruno
Sorry, we would just return the camera to the manufacturer for repair, therefore I don't have any component details.
Maybe somebody else will come along with information to help ...
Thank's, but I'm electronic repairer (mainboard, micro component etc), it would be sufficient to find the suitable leds.
Bruno
If/when you do find the correct LEDs, please feel free to come back here and share,
Ciao Dixibru, puoi dirmi se hai trovato i LED giusti per riparare la scheda perché anch'io ho lo stesso identico problema, mi faresti un grande favore per darmi qualche notizia.
Ti ringrazio anticipatamente.
Hi Dixibru, you can tell me if you have found the right LEDs to repair the board because I too have the exact same problem, you would do me a huge favor to give me some news.
I thank you in advance.
