Pepwave 4g router wont fully reset...
Markus19
Hi guys so i have second hand pepwave max transit 4g router that im trying to use
Ive got one data sim in it which is connecting.
The issue im having is it keeps going back to a old network likey setup from the past owner..
Ive tried to hard reset it by holding in the reset button for 15 seconds and at first the router is back to its orginal self and i can log into it via ip address and admin admin however after around 20 seconds it disconnects and the name of the router goes from its factory name to a pass users custom name... and then i obv get logged out the browser
Ive tried in the 20 seconds to even turn of in 2 control and even when that is off its still doing the same thing...
I cant understand as i would presume a hard reset should wipe out all pass details and keep them out however it keeps defaulting back to the pass owners network..
Can any one help with this
Could you post a link to the technical specifications?
David
This is is
@Markus19
Similar question here, can you try it?
There is probably a security feature enabled to automatically reconfigure the device. Disconnect all the antennas just after the factory reset has finished.
David
