Playback Stuttering from 1 camera
L Bishop
I have a two camera setup,DS-7604NI-K1/ DS-2CD2386G2-IU AcuSense 8MP Darkfighter turret camera IR & Mic.
I have noticed that when I playback one of my cameras it seems to stutter when a person comes in view, for a second or so. Any idea what this could be? Thanks
Hi @L Bishop
This is likely a bandwidth issue, the DS-7604NI-K1 NVR only has a 40Mbps incoming bandwidth limit which was fine when the NVR was first released but now the new 8MP AcuSense models are producing more than 20Mbps each, so only 2 of these may have exceeded your NVRs bandwidth limit.
Are you able to share a screenshot/photo of the video settings for one or both of your cameras to see if there are any changes we can recommend that might improve stream stability?
Hi, many thanks for the reply.
I have now changed the settings to the below pictures, and seems ok . I want to add two more 8mp cameras on the system, will it cope ok?
The 7604 NVR definitely will not be able to manage 4 x 8MP AcuSense cameras without you reducing the resolution, frame rate, and setting them all to H.265+
I'm surprised you are getting stable performance from 2 x 8MP cameras that are on H.265, max. resolution, and max. frame rate. We would definitely recommend reducing the frame rate to 15fps because unless you are dealing with very fast-moving vehicles you are not going to notice a massive difference in performance between 25fps and 15fps, but it will save quite a chunk of bandwidth.
Ok cool, so will drop to 15fps, shall I turn on H265+ and alter the resolution? Any help welcome
Hi @L Bishop
Yes, you would need to reduce all of the above settings to get 4 x 8MP cameras to work, but reducing the resolution would make buy 8MP cameras pointless as you would be reducing the resolution to 6MP or lower.
If you want to record 4 x 8MP AcuSense cameras at full settings you would need to use a DS-7608NI-I2/8P 8-channel NVR which supports more incoming bandwidth.
