I've got a new NVR (HWN-4101MH-4P) and four used bullet cam (DC-2CD1043G0-I).
I can connect the cameras via the POE ports, and I see that they are powered well, but I can't connect them in the NVR neither the SADP. When I want to connect them, it says "The destination is unreachable".
DHCP is enabled, the NVR's internal IP is 192.168.254.1,
a cam's IP is 192.168.254.2, etc...
Maybe I should reset the cameras, but I don't know how.
Maybe If I could connect the directly into the SADP, I could reset them, but because I can only give them power via POE, I can't use them without the NVR.
What should I try?
What should I try?
