FAQ Which software to use if you have three different manufacturers of ip cameras (IOS and Android)
mornwood
HI Which software to use if you have three different manufacturers of ip cameras at home to stream all camera in one app (IOS and Android)?
Does somebody known ?
Do you already record them?
If so, then an App compatible with / provided by the recording solution.
For example, Synology NAS boxes have compatibility with a very wide range of brands and cameras.
And they provide their DScam App to access the solution from your mobile.
Thanks for the answer. I found application on apple store who can connect different manufacturers IP cameras. I tested and it works great. I have connected three different manufacturers ip cams that have local storage on SD card. Live stream and playback are working great. All cameras are supporting ONVIF protocol. I have solved my problem. If somebody has the same problem here is the solution (MVR: Onvif & IP cam viewer)
