Hikvision Speed Domes G3 vs R7
vvv850
Hi all,
I am having difficulties in finding out the differences between G3-IPDE and H7-IPD PTZ families. Can someone help me out? Thanks
Hi @vvv850
Hikvision support has shared the attached table comparing the G3 & H7 PTZ Families
Under PTZ > Pattern for the G3 Family you will see it is partially cut off, what it actually says is "Partial Support (except DE3A)"
Thank you very much for your support. Going through the screenshot doesn't provide much info (at least for me).
To provide more info: I have decided upon two PTZ Domes:
DS-2DE7432IW-AE(S5) (G3) and DS-2DE7430IW-AE (H7)
I am not really sure what the main difference is between the two. Could you help me in this regard?
Thank you
Ok, the main differences between those 2 models are listed below:
AcuSense: DS-2DE7432IW-AE(S5) - supports AcuSense / DS-2DE7430IW-AE - Does not support AcuSense
IR Range: 2DE7432 - 200m / 2DE7430 - 150m
Optical Zoom Range: 2DE7432 - 32x (4.8mm to 153mm) / 2DE7430 - 30x
Most importantly though, from our digging for these specs we have found that the DS-2DE7430IW-AE model would appear to now be End of Life.
