How to show a custom view as startup default
Rick47
Using iMVS-4200. A rather basic question, but I can't see anything in the forum or the Hikvision Help.
How do you configure the client iMVS-4200 to start with the custom view that I've created?
Currently it comes up with the standard 4 image view and I have to manually select my custom view (6 cameras as 1 main image and 5 smaller). That's not a big deal I agree, but most apps have a default startup position.
The word 'default' in the iMVS-4200 only seems to relate to the 4 preset views (under Deafault), but I can't see anywhere to set my custom view as the default at startup.
You can achive that in version: iVMS-4200 following the next steps:
1. Go to "Main View" and set up the "Custom View as you wish"
2. Once you have the desired view, click the small button at the bottom left of the screen called "Save View"
I hope it helps
