Hik-Connect Updating DS-7716NXI-I4 / S to latest firmware broke Hik-Connect / Web browser usage?
JeromeTR
Hi everyone,
I am new here, Hikvision support isn't getting back to me at all about this.
I recently bought a DS-7716NXI-I4/S NVR - which came with firmware V4.40.805 Build 210128.
On LAN1 of the NVR, it connects to my main network switch. On LAN2 of the NVR, it connects to a switch that my 16 IP cameras are connected to.
This setup worked perfectly for almost 8 months with no issues at all.....until I updated the firmware to V4.62.205_230220.
After updating, I am unable to use the NVR properly at all !
When using my browser (I tried Firefox, edge, chrome) it suffers to connect to the device and I must constantly reload the page to get to what I need.
The live view works for 5-10 seconds, then "goes blank" and doesn't display anything. On my Hik-Connect app, it gives me an error of Error Code: 330007.
I have googled it and tried changing the network settings as suggested, but that did not work. I have also tried to Reset NVR to factory and start again from scratch (no loading of backups) and changed the network switch and replaced all cables going to cameras. I've run a constant ping to the NVR and there is no packet loss.
So I guess the firmware broke the NVR.
Has anyone experienced this or can recommend a solution?
Hi @JeromeTR
Did you update straight from v4.40.805 to v4.62.205 in one update?
If you did, this might have caused some software glitches. Maybe try downgrading to v4.51.200 and if that works check if the issues you've been seeing are still there.
If it works and the issues are not present you can then try upgrading to the latest version in steps by updating to each of the below firmware versions one at a time:
V4.60.100
V4.61.066
V4.62.205
Hi @Dan
I have tried to downgrade and get the error message as shown on the attached file.
What can I do now ?
I have tried all versions that you suggested (starting with lowest to highest) and I get the same message each time.
Any other suggestions???
Should I contact the supplier/manufacturer and return the device ?
