Extending Qvis Falcon NVR IP camera system with Wifi Camera
Fozzie Bear
I am looking for a bit of help with adding another camera to my existing system.
I have an Ony-x Falcon FALC-NVR-8BB NVR and 3 bullet and 2 turret 5Mp Qvis cameras. They are all still working fine, however I need to add another camera and I can't get an ethernet cable or coax to its proposed location on the gable end of my bungalow. The ceilings are all vaulted at then end of the property so there is no loft and access to run ethernet cables. However there is an old BT downcomer from the old analogue line that I can use to supply 12v supply to the camera.
I therefore need a wireless CCTV bullet camera that will work with my existing NVR. Note that I do not currently us the built in POE ports on the NVR but have all the cameras now on my LAN using a separate POE switch.
I was looking at the Reolink RLC-511WA ( I know this has been superseded by the RLC-811WA but I only need 5Mp). I have a good strong mesh wifi network so if I connected it to that can I still add the camera to the Falcon NVR. As outlined above all the cameras are on my Lan via a POE switch so they are all on the same IP subnet.
Many thanks
Can anyone help me with this please? I just need to understand if a wifi camera can be connected to an existing IP NVR and what features the camera should support to enable this?
Thanks in Advance
